Aja Roi instead of a patch generator?
Author Knut Jansohn
#1 | Posted: 13 Oct 2015 13:25
Hi
I'm considering to purchase an aja roi https://www.aja.com/de/products/mini-converters/roi-dp
Just to feed the display SDI-in from the DP/Hdmi out of a notebook with LS signals
Any experiences with it -or arguments to scrap the plan?
#2 | Posted: 13 Oct 2015 13:28
Should be fine - although I've never used one, as have never had any need...
Author Knut Jansohn
#3 | Posted: 13 Oct 2015 13:38
Wow that was a quick reply
So how do you feed the SDI in from the notebook (running LS)? Patchgenerators seemed to be pricier...And I don't like to tinker with a second Laptop and resolve etc
#4 | Posted: 13 Oct 2015 13:41
I only ever use the actual workflow the display will be used with - so via the DI system for grading set-ups.
For displays that are used separately, I usually use HDMI.
If I really need separate SDI I do use a patch generator, such as IS-mini, DVDO, etc...
