AJA LUT Box now availabel for global delevery
#1 | Posted: 9 Aug 2014 14:21
The new AJA LUT box is now available for delivery globally.
See: http://www.lightillusion.com/aja_lut_box.html
#2 | Posted: 22 Oct 2014 22:19
New software for AJA LUT Box!
http://www.aja.com/en/products/mini-converters/mini-config-software#support
Fixes recent issues.
Seems I had a different (beta) version so didn't see the issues this fixes!
Author Westwing
#3 | Posted: 24 Feb 2015 17:09
Does the AJA LUT Box support 3D Luts from Resolve?
#4 | Posted: 24 Feb 2015 17:22
The AJA LUT box supports LUTs in different formats, including the .cube format.
But only in 17^3 format.
Most LUTs used within Resolve are of a larger format, so cannot be loaded in the AJA box without first being converted to the correct size.
Author Westwing
#5 | Posted: 24 Feb 2015 17:31
What would you suggest using that can take the Resolve LUTS?
#6 | Posted: 24 Feb 2015 17:36
We don't use Resolve directly, so can't comment.
Obviously you can use LightSpace LUTs to convert LUT formats and sizes as required.
Author Westwing
#7 | Posted: 24 Feb 2015 18:10
Will light space run on Mac? Or under virtual PC mode? What about the Fuji IS, will that take Resolve LUTS?
#8 | Posted: 24 Feb 2015 18:13
LightSpace CMS - all versions - will run on a Mac using any Windows emulation.
We have fully integrated the IS-mini with LightSpace, so you can direct load any LUT from LightSpace into the LUT box.
We never use the IS-mini on its own, so can't comment on the LUTs it may load, but I think they are of the IS-mini format only...
Author Westwing
#9 | Posted: 25 Feb 2015 10:45
Thanks Steve! Just trying to find a workflow that is quick and easy on set. Looks as though I'm going to receive a LUT from the Post House, which I'll then have to convert, either to a format that can be read by a LUT Box or with software that can convert to an Arri Look file .xml.
Does LightSpace LUTs convert any 3D Out to an Arri Look file? If so, are there any caveats to this procedure?
Simon
#10 | Posted: 25 Feb 2015 11:39
For Arri Looks you will need LightSpace LUTs+
Info is on the relevant page of the website
Author Westwing
#11 | Posted: 27 Feb 2015 11:56
Is LightSpace LUTs a standalone app?
#12 | Posted: 27 Feb 2015 12:33
No, it is a licence within the LightSpace CMS product, that just allows for LUT manipulation.
That means you can upgrade to other versions at a later date...
