Adobe RGB ColourSpace
Author howellsaaron Male
#1 | Posted: 22 Mar 2022 04:12
Seeing as there are monitors that have direct ColourSpace intergration (eg SW321C,CG319X) also have the Adobe RGB colourspace, would you consider adding this to ColourSpace?
I know users can add and modify Colourspace's but I wouldn't know where to find the space to add myself. I am also looking at buying one of these monitors and would like the option of Adobe RGB calibration directly through Colourspace.
It's not an urgent priority I know but it would be good if you would consider adding this Colourspace to the program.
Thanks for your time.
Aaron.
#2 | Posted: 22 Mar 2022 07:48
As Adobe RGB is not a valid colour space for the Film & TV industry we deliberately have never added it as a preset.
Red: 0.6400, 0.3300
Green: 0.2100, 0.7100
Blue: 0.1500, 0.0600
White: 0.3127, 0.3290
EOTF 2.2
Peak white 160 - 200 nits.
#3 | Posted: 22 Mar 2022 08:15
Thanks for the reply, Yeah I thought it wasn't a focus for you because you seem to be more film and Tv.
So if I was to go to Rec709 for example and modify the primary's and white with the x and y values you provided then save that as a user modified space would give me the adobe rgb space?
Thanks.
Aaron.
#4 | Posted: 22 Mar 2022 09:07
Rec709 is EOTF 2.4, so you would need to change that too.
Or use sRGB as the starting point, as that is EOTF 2.2.
(Ignore those that talk about a compound EOTF/Gamma - that is wrong for any sRGB display calibration.)
#5 | Posted: 22 Mar 2022 09:12
Thanks Steve,
I have modified the colourspace with the Adobe RGB primaries and 2.2 EOTF. It is amazing that I as a user can add any Colourspace that I wish, just goes to show how powerful the software really is.
Thanks.
Aaron.
