AccuPel Operation & Workflow
Author alex_t
#1 | Posted: 8 Aug 2014 05:38
I've seen that LSCMS allows using an Accupel patterns generator : AccuPel Operation & Workflow.
I guess LSCMS HCL supports it as well because no restriction appears in the release note. Could you confirm ?
Thanks.
Alex
#2 | Posted: 8 Aug 2014 06:53
The Accupel license is the same as the Radiance...
Author alex_t
#3 | Posted: 9 Aug 2014 07:12
Thank you Steve
