3D cube viewer
Author alex_t
#1 | Posted: 22 Sep 2013 09:55
Hello all
If I well understood, the 3D cube viewer allows showing the 3DLUT result. Is there a way to have the same 3D view but for the profile measured ?
alex
#2 | Posted: 24 Sep 2013 13:27
Hi Alex,
At the moment that's not possible - but it is something we are looking at for the future as it will be far superior to the standard Delta-E approach.
But, the LUT does show you the profile accuracy, as any deviation in the LUT from a pure 'cube' directly represents the inaccuracy in the display.
You can see some info on this here: http://www.lightillusion.com/delta-e.html
Author alex_t
#3 | Posted: 28 Sep 2013 08:15
Hi Steve.
Thanks and sorry for my late reply. I hope that you will be able to add this feature in LS.
If you don't mind, I would like to send you the 3D CUBE view for comments.
Regards
alex
#4 | Posted: 28 Sep 2013 08:59
Hi Alex - send me the .bcs profile file and the LUT you made from it.
I can then assess the data.
Author alex_t
#5 | Posted: 28 Sep 2013 11:40
Steve, thanks. I'll send you the data soon.
alex
 3D cube viewer
