2026 LG OLED Patchsets
Author DNice
#1 | Posted: 16 Apr 2026 15:24
I have not seen these available anywhere, so here you go.....
2026 patchset.zip Attached file:
2026 patchset.zip
#2 | Posted: 16 Apr 2026 16:10
DNice
Thanks - that's great!
We will also ad 24 point control to the Interactive LG Controls within ColourSpace shortly.
Author SamuriHL
#3 | Posted: 16 Apr 2026 17:57
Awesome thanks for this!
Author DNice
#4 | Posted: 16 Apr 2026 21:19
You're welcome. The PQ values will allow owners to calibrate Dolby Vision now since Dolby "Calibrate" (gamma space) is currently broken and/or get better EOTF tracking in HDR (HDR gamma space triplet values should use the same as used in SDR).
i1D3 probe users should take note of the first grayscale point triplet value 80 80 80 (10bit). It equates to roughly 0.007 nits which is well below the chromaticity accuracy of those probes (even the K10-A/CR-100 will have issues at that luminance level). I recommend you change the value to at least 116 116 116 (10bit).
Author Hotneca Male
#5 | Posted: 29 Apr 2026 06:53
DNice
Thanks for your kindly sharing
