WIBNI requests x3.
Author davem
#1 | Posted: 20 Mar 2025 20:24
For the "WIBN" list:
1. To allow manual readings to be made when "Stabilisation" is selected
2. To be able to overwrite and replace an existing Workflow configuration, after making small updates, rather than having to delete the Workflow and then save a new one with the same name.
and
3. When displaying measured "Auto" Extra Delay measurements, to add a "+" to the beginning of the measurement if it's 0.00xxx and the display is truncated to 0.00
I've found it's easy to make a manual entry of "0.00" , thinking that that was the measurement and getting unexpected bad probe readings.
Thanks Dave
#2 | Posted: 21 Mar 2025 08:05
Manual Measure can already be used with Stabilisation, so not really sure what you mean.
The Stabilisation patch is shown when no Measurement is being made, with the correct patch displayed when a Measurement is taken.
But, if you want to display the 'measure' patch for longer, when no Measurement is being taken, but also have some 'Stabilisation', you can simply use a Patch Set with the required 'Stabilisation' colour, and just click it to display as required.
(When you have a .csv Patch Set you can click any of the patch colours to directly display them.)
With ColourSpace, when you have any 'saved' file you cannot overwrite it.
That is standard ColourSpace workflow to prevent any data being inadvertently overwritten.
That will not change.
And yes, the Extra Delay value has too few decimal places.
We will change to 3 decimal places, as that is the actual granularity of that function.
Author davem
#3 | Posted: 21 Mar 2025 10:00
Manual measurements with stabilisation selected:
My bad.
Some how I managed to get a measurement equal to my Stabilisation patch and turning Stabilisation off corrected it.
Having checked it again, I can't fault it.
I don't know how I got that to happen.
Sorry for the confusion.
Workflow updating:
The reason I say it would be nice to be given an option to replace an existing workflow, is that I have mine named with reasonably detailed descriptions, in order to group the different display models separately and order the stage of the calibration correctly. So I don't want to save the changed workflow with a different name.
I also want the old one to be gone, to avoid the possibility of using it again by accident.
To do this at the moment, I delete the workflow I've just loaded and then save a new one with the same name.
I usually get the description right, but not always.
I'd pondered that it'd be nice to have a pop-up window, asking if you're sure you want to replace this workflow, but I totally get it if this breaks with conventions across the rest of the package.
Extra Delay decimal points:
I only mention this because I got myself caught out one time.
It took a while to figure out what was happening.
I mention the "+" sign to signify that there are more digits, because Klein do it in their ChromaSurf app.
The other reason is that I have no idea how many decimal points would be needed.
Dave
#4 | Posted: 9 Apr 2025 16:28
It would be nice that, if same mimic used for profiles is used: i.e. proposing samename_1 for saving, so that later, you don't have any doubt about what to delete later
#5 | Posted: 10 Apr 2025 09:52
That is not possible, due to the active workflow very intentionally defaulting to 'Default' between ColourSpace close/open operations.
#6 | Posted: 10 Apr 2025 10:31
Ya, off course if you are modifying in the default case wf, it does not make sense being offered with a default_1
But if you are not in the default case, it would be useful (and I guess possible)
#7 | Posted: 10 Apr 2025 10:44
No, as Default is a special case name.
But doesn't mean something can't be done - just not quickly.easily.
Already on the WIBNI list.
 WIBNI requests x3.
Members - 1 (hidden: 1)
