v 2.0.0.2481 - Auto Extra Delay
Author titleexaminer92 Male
#1 | Posted: 7 Nov 2026 18:25
Freshly installed v 2.0.0.2481 and attempted to use the Auto Extra Delay function with my CR-100 using PiTPG as the pattern generator.
This caused a white patch, a low luminance patch, a yellow patch, and a cyan patch to be shown on the display's screen, but it appeared to be stuck in an endless loop. The sequence only ended when I manually aborted it.
ColourSpace HTP
CR-100 / CR-250-RH / PiTPG
#2 | Posted: 7 Nov 2026 18:29
That likely means the display was unstable, or the probe is set to alter its own settings based on measurements.
Auto Extra Delay does need stability for both display and probe settings.
There should be a timeout, but I confess that may be set to a long duration.
#3 | Posted: 7 Nov 2026 18:40
Thanks for the prompt reply.
Attempted the process with Intelligent Integration disabled and the Auto Extra delay function completed after 6 cycles.
ColourSpace HTP
#4 | Posted: 7 Nov 2026 18:48
Ah - the User Guide does say that Int. Int. should be disabled - or at least it did when I wrote it.
I'll check it still says that.
#5 | Posted: 7 Nov 2026 18:58
Yup, looks like it still does. Sorry for the false alarm. Thanks, Steve.
ColourSpace HTP
#6 | Posted: 7 Nov 2026 20:18
I recently ran Auto Extra Delay, and it completed just fine. Luckily, I had previously changed from Period to AIO in meter settings, also turning off Intelligent Integration at the same time. Otherwise, I may have made the same complaint in error...
#7 | Posted: 7 Nov 2026 20:34
With Int. Int. and Average Low Light on you will (should) get a valid value... Eventually. But it can take a seriously long time, as all processes run extended durations.
And for the Extra Delay value there is no actual benefit at all in having Int. Int. and Average Low Light enabled - that we can think of.
But, as with all things ColourSpace, we do not disabled them from being used, as you just never know if a user may want to enable them for some reason we have not thought of...
