Stabilization patch popping up during measurements.... [Fixed]
Author titleexaminer92 Male
#1 | Posted: 26 Apr 2025 20:39
While I was running my 1000 pt verification sequence on a 3D LUT calibration, checking or unchecking boxes on the de filters caused the stab patch to show up on the display, same with clicking on a respective point on the CIE chart to view its info.
ColourSpace HTP
CR-100 / CR-250-RH / PiTPG
#2 | Posted: 26 Apr 2025 20:47
Your getting good at finding such issues!
We'll look into it.
#3 | Posted: 26 Apr 2025 20:50
What can I say? I like to tinker when running long patch sequences.
ColourSpace HTP
#4 | Posted: 26 Apr 2025 20:55
Indeed, and you should be able to, especially with higher license levels with multi-threading.
Please do check all other GUI controls for any similar issues!
#5 | Posted: 28 Apr 2025 13:54
Fixed in present release.
Members - 1 [ HeBer_nl ]
