Stabilisation Patch not reapplied in Manual Measure [Bug]
Author davem
#1 | Posted: Yesterday 01:23
It's not the end of the world, but I notice that if you have a stabilisation patch selected and you do a measurement, it doesn't reload the stabilisation patch once the measurement has been made.
It always used to.
Author davem
#2 | Posted: Yesterday 02:07
I should add that the above refers to a manual measurement.
If it's part of a sequence the the stab frames do get inserted.
#3 | Posted: Yesterday 08:45
Good find.
We'll fix that.
