Open Beta ..... Something wrong in Manage Type column [Not A Bug]
#1 | Posted: 13 Mar 2023 14:22
Type column info looks truncated ..... I have a full HD screen (1920x1080 with 125% recommended scaling). I have never had such an issue before beta.
#2 | Posted: 13 Mar 2023 14:39
Have a look at the Interactive User Manual.
All is explained there...
(Click on the Profiles (user) library element.)
#3 | Posted: 13 Mar 2023 17:20
Hence you have to display/modify the relevant profiles (and close, otherwise you get in troubles) to have "Type" fully populated ......
Anyhow the most important thing (i.e. the Profile Mode) is there.
Somehow useful that the absence of "..." at the end means you have already opened that profile
#4 | Posted: 14 Mar 2023 10:36
Addition: Not sure if it is intended, but when "profile user library elements are listed (the first time, after CS loading), Gamut Sweep and Memory Colours are reported as generic Profile:
You can see in the below picture the Characterisation mode used, what appears at first listing and what appears after having displayed the elements
Also annexed the generated bcs.
New_1_1_1_1_1_1_1_1.zip Attached file:
generated bcs
#5 | Posted: 14 Mar 2023 12:16
Yes, that is as expected, as the associated metadata has not been loaded.
(Some basic metadata is extracted on the initial scan, but not all.)
We have plans to treat the metadata separately from the actual profile, but that's a later development.
