Names of user defined Profiles and Color Spaces should be independent from each other [Answered]
Author erazortt
#1 | Posted: 8 Jan 2022 13:02
If there is a Profiles with a certain name, it is not possible extract Colorspace and save it with the same name. The error says that there is already a file with the same name.
#2 | Posted: 9 Jan 2022 16:06
Yes - you cannot have profiles or colour spaces with the same name.
They must be unique.
Author erazortt
#3 | Posted: 10 Jan 2022 21:04
Yes, thanks for confirming what I wrote. You reply like it should be so obvious that that is the way it should be. But that is not the case!
Especially since the error message says: Can't overwrite existing colour space.
But when looking for all saved colour spaces in the Manager there is no colour space with that name. So at the very least the error message should be rephrased.
But actually I really think that there is no logical reason why a colour space whould not be able to be names like a profile. There may be technical reasons, but technicalities can be changed.
