LUT generation hangs [Not a Bug]
Author ulrichd
#1 | Posted: Today 02:30
I have a profile which consistently hangs the LUT generation profile process. The source Gamut profile is Rec709, destination the attached file. I have "normalize code range" enabled. Output name I set to "X700 SDR", the "Peak Chroma" drop-down I set to Fit Space, and the rest uses defaults. When I hit Create, it brings up the "working" window, but the progress bar never moves. I let it run for more than 30 minutes, but nothing happens. I had to close ColourSpace via Task Manager.
As a test, I tried an older profile from 2020 and that LUT generation completes but while it calculates it never showed a progress bar either.
I'm on build 2424 (still working with Ted's patters via PGen). I have an HTP license.
Let me know if I need to provide any other details.
X700R u1 cp c2 after gamut c.zip Attached file:
X700 large gray ramp profile
#2 | Posted: Today 08:51
You have profiled the display with Extended, but all values above 100% white are clipped.
The EOTF graph shows you that.
ColourSpace is not hanging, it will just take ages to try to generate a LUT from an invalid profile.
Clipping
Clipping
