Issue with stabilisation patches (v1.0.0.2116) [Fixed]
#1 | Posted: 6 May 2025 16:37
I think I have gotten on a fly a v1.0.0.2115
The only difference on the change log being:
1.0.0.2116 – incremental changes
-- Fixed issue with Stabilisation and changing some settings while profiling
1.0.0.2115 – incremental changes
-- Fixed issue with Stabilisation and update of Target Min/Max Luma while profiling
Anyhow, not important, but maybe it can help you to understand what's happened.
What I have noted a different behaviour of of stabilisation patches with Pgen. I have used as probe a Promethus set at 0 extradelay (but also with a Klein I have got a similar behaviour. Pgen was connected directly, no internet connection, so only the minimum windows 11 background
I has set a grey patch with stabilisation .250 and FS,
What happens in 2116 is that some of them (quite a lot, depending on the colour/luminance) patches stop appearing on the display, Installing 1.0.0.2115 it works fine as I know also from previous releases.
I have taken a video using the patch colour, that is in line with what I see on the panel; https://1drv.ms/v/c/6b5b8bf23b77dd0a/EUMrgQN_JndPkzJS4fFrpfQBjA2-BxauC7asBioLZVA4fQ?e=sGDipx
I have also tried to use a tight stabilisation values, i.e. 0.100 second. What I see is that with 1.0.0.2115 stabilisation patches appears in a "ordered way" on the display. Always pretty same time stabilisation. That ordered way disappears with 1.0.0.2116.
See here the 1.0.0.2116 video: https://1drv.ms/v/c/6b5b8bf23b77dd0a/Ea2yuwInKwlIsowWY_cVc3cBIkRI3h016MAY_9LR4rAh5Q?e=QXmOQc
and here the 1.0.0.2115 one: https://1drv.ms/v/c/6b5b8bf23b77dd0a/EZx1muuH98FNtwUPThatL-EB3g_A8hjlhzRRKnRXj0APjQ?e=F9gqh5
#2 | Posted: 6 May 2025 17:29
Sorry, but I really cannot follow what you are describing, or the videos.
But, please take PGen out of the loop, and then test again.
#3 | Posted: 7 May 2025 06:32
Here it is (with 100 msec FS stabilisation patch)
1.0.0.2116: https://1drv.ms/v/c/6b5b8bf23b77dd0a/ETpeTZcnw41DmMkmWOVpc2ABbV0JPOZ2lWlPhecVNZtU3g?e=4OxHnv
1.0.0.2115: https://1drv.ms/v/c/6b5b8bf23b77dd0a/EUgRRUHpTQlDhziv3i15Js0BA9zRl-SMJMhlFwgMTJ3swA?e=QmIQNm
#4 | Posted: 7 May 2025 07:14
Ok - the next question is what value of stabilisation causes correct patches?
And does the same issue happen with an i1D3 probe?
I cannot duplicate, so it may be a speed issue with your PC. or some other connection issue?
Or some other setting you have not defined?
#5 | Posted: 7 May 2025 11:54
Ok - have duplicated.
We can look into it now.
#6 | Posted: 12 May 2025 19:11
Fixed in next release.
Online now: Guests - 7
