i1Display Pro Plus - no Visible Feedback [Answered]
Author tallLeRoy
#1 | Posted: 3 May 2023 15:47
Using ColorChecker / i1D3 on latest ColourSpace, the Enable Visual Feedback LED has no noticable effect on my i1 Display Pro Plus. The older driver flashed the LEDs on the sides when the probe was idle. NOT a big deal.
LeRoy
#2 | Posted: 3 May 2023 16:18
The LED flashes at the end of each reading...
We very specifically do not just randomly flash the LED when the probe is doing nothing.
Author tallLeRoy
#3 | Posted: 3 May 2023 16:59
Ah, yes that is what it is supposed to do. Mine does not. Hence the bug report. It worked like that before the change to the new driver.
Mine will blink when powered up with USB with no program controlling it. So the LEDs work.
#4 | Posted: 3 May 2023 17:00
Have you taken readings, and watched the LED?
It will flash only when a reading is taken.
Author tallLeRoy
#5 | Posted: 3 May 2023 17:28
Hi Steve, love your product.
Yes, full 4000+ profile overnight, then 1000+ verification. Unhappy with the results (Too many orange points, good average though. ) So just did another 4000+ profile, and it is doing the 1000+ point verification as I write this. No flashing after each reading, not even faintly.
I wanted to try the new drivers, so far, I think my C2 changed the way it handles Service Menu White Point. Once the 3D LUT is reset, it reads as if the Warm Service Menu White Point is 192,192,192. May have been in a firmware update since my last calibration of the C2.
LeRoy
#6 | Posted: 3 May 2023 17:30
What speed are you reading?
If the probe read time is fast, it will not flash, as there is no time between the reads to do so.
Try a Manual read of a few frames to test.
Author tallLeRoy
#7 | Posted: 3 May 2023 18:16
integration time 0.5, extra time 1.00.
BTW extra time is not sticking around anymore.
Did the manual measures, no change.
#8 | Posted: 3 May 2023 18:19
Presently, Extra Time, as well as the other settings in 'Probe Adjustments', are not being remembered...
That will be fixed.
I've just tested every different i1D3 we have here (and we have a lot), and all flash the LED after each read.
Author tallLeRoy
#9 | Posted: 3 May 2023 18:33
I have an old OEM and an old Pro model here. I can dig them out and try them. I will let you know what I find with those.
Author tallLeRoy
#10 | Posted: 3 May 2023 18:58
Interesting, hooked up the type A pro, flashed. hooked up the type A chromapure OEM, flashed. Reconnect the type b pro plus, flashed. Problem solved.
My prior probe last night was my i1 Pro 2. Maybe something about the order of connection. I did the close open routine for ColourSpace, and full reboot of the Windows 11 machine before starting this thread.
Very interesting
Thanks for your replies, Steve
LeRoy
