HSL adjustments don't work properly [Fixed]
Author mecedo
#1 | Posted: 27 Jul 2021 07:31
In ColourSpace ZRO (1160 and 1180 release) in HSL adjustments H lever doesn't work properly. It stops on value 100 but should on 360.
#2 | Posted: 27 Jul 2021 10:36
mecedo
HSL is lock to work in % mode, not degrees.
This is stated in the User Guide: https://www.lightillusion.com/colourspace_manual.html
"The R G B slider header button can be toggled to change the sliders into HSL mode, enabling the patch colour to be set using Hue, Saturation, and Luminance, as percentage values, matching some TV's own CMS controls."
This is also shown in the GUI, with the % tick box selected and greyed-out.
Author mecedo
#3 | Posted: 27 Jul 2021 13:46
But how to obtain 100% blue color on HSL adjustment? I can't. Even if I set 100% blue on RGB slider and switch to HSL then color immediately is set to green.
#4 | Posted: 27 Jul 2021 13:49
Oh!
I see what you mean now!
You had not provided enough info before...
Yes, that is wrong.
We'll look into it.
(Shows how few people use HSL mode...)
#5 | Posted: 30 Jul 2021 14:44
Bug found and corrected.
Fix will be in the next release.
