Gamut Triangle Level [Fixed]
#1 | Posted: Yesterday 17:18
Hi, Steve. V2519 seems like it may be tripping up when drawing the gray line to indicate the measured gamut. A French member on another forum indicated his gamut was shown "only about 25% of its normal size" using 2519 but that things were normal when reverting to an earlier version. I just ran a Grey, Primary, and Secondary Ramp+ on our Samsung S90. Measured points plotted roughly where they had many times in the past. The only thing noticeably different was the grey line denoting the boundaries of the measured gamut. Even so, the gamut coverage calculation was at 96%. I'm going to try to attach my saved profile for your perusal.
Note: I just went back and viewed the saved profile, and the drawn gray gamut line is now correct. It seems that the error was visible when the line is drawn initially, but going back to display the saved profile shows it correctly. Weird.
New_Rec709_2519.bcs.txt Attached file:
Rec709 gamut measurement
#2 | Posted: Yesterday 18:15
You do know you can select the Gamut Triangle Level?
The option is in Graph Options.
Users have always have been able define this.
#3 | Posted: Yesterday 18:48
Actually, there is a change here.
During profiling the Gamut Triangle Level is not updating.
The change has happened as part of the measurement speed-ups.
So you will need to set the level from the Graph Options.
I'm actually not keen on this change, so we'll look at it.
#4 | Posted: Yesterday 19:08
Thank you, Steve. I did know about the Gamut Triangle Level setting, but it's not something I ever use, so it slipped my mind.
I just thought you'd like to know before it started being reported specifically as a bug.
#5 | Posted: Yesterday 21:24
Yep - we decided that was a bug, and have changed it so it again works as before.
The fix will be in the next release.
