Extraction of Builder Probe Data Failed [Fixed]
Author bundy115
#1 | Posted: 15 Mar 2025 17:28
All of a sudden, I am getting an error dialog when I try to extract BPD for use with configuration matching as follows;
I select the desired profile, choose modify, and then click on Extract BPD. The save dialog appears but after clicking save I get the following error dialog...
"Extraction of Builder Probe Data failed."
This happens with new profiles I have just created, as-well-as older profiles that I have successfully extracted BPD from in the past (albeit with a different software version).
I am using the latest version 1.0.0.2090 with an LTE licence.
Thanks in advance for any help.
#2 | Posted: 15 Mar 2025 17:35
Thanks - we'll look into that!
Author bundy115
#3 | Posted: 15 Mar 2025 19:23
Thanks.
The only thing that's changed on my Windows 11 machine is the installation of Cumulative Update 2025-03. I have also tried re-installation ColourSpace.
Andrew
#4 | Posted: 17 Mar 2025 07:44
It is a ColourSpace bug.
We will fix in the next release.
Author bundy115
#5 | Posted: 17 Mar 2025 13:27
Thanks for the prompt resolution.
