DVDO and SEVEN-G issue in latest build [Fixed]
#1 | Posted: 8 Aug 2021 08:56
We've just realised a change we have made in readiness for separating madVR HTPC and madVR Envy has broken the DVDO and SEVEN-G hardware operation.
(madVR Envy is gaining capabilities that are not available in madVR HTPC.)
A fix will be released as soon as possible!
#2 | Posted: 9 Aug 2021 09:19
Ah!
It turns out that this is not a 'bug'.
But, as new hardware has been added to ColourSpace (not that any user can see the new 'madVR Envy' option as yet), the .ini file will initially be wrong.
This will (should!) self correct after ColourSpace has been opened and the various hardware options accessed for the first time, and ColourSpace then closed and re-opened.
Or, the user can delete the old .ini file, and a new one will be started automatically.
(The user will need to select different Hardware options, to have each selection remembered into the .ini file.)
#3 | Posted: 9 Aug 2021 10:03
An Update
We will be making a change to (hopefully) make the process easier any time we add/change new Hardware options...
A new build has now been released.
