Dark Themes info window [Known Issues]
#1 | Posted: 25 Aug 2025 15:31
I am surprised I am the first to note. Have a look:
Info windows (dark scheme)
Regardless the colours you read/display, the colour displayed in the info window is always white
To tell, that I have not noted anything else.
#2 | Posted: 26 Aug 2025 10:32
Also manual measure setting has some visibility issues:
Manual measure (dark scheme)
#3 | Posted: 26 Aug 2025 15:47
From the Update Release info.
Known Issues
With the new Dark theme there will be some outstanding display irregularities.
And the internal patch window can jump sizing on screens that are using a Windows Scaling value other than 100%, when ColourSpace is running on a different window with different Scaling value.
These issues will be addressed in a future release.
#4 | Posted: 28 Aug 2025 07:42
I had checked before posting. But it is so generic, that I have thought it does not apply to the pop up windows displaying.
But, anyhow, 100% usable (so I have not gone to the CS system parameters to disable it)
#5 | Posted: 28 Aug 2025 07:57
Sending such feedback is fine.
Just letting you know we are aware there are issues.
