ColourSpace not displaying Colorimetry Research CR-250 readings after probe change [Info Needed]
Author davem
#1 | Posted: 6 Jun 2023 09:47
I've noticed what appears to be a bug.
Running ColourSpace v1.0.0.1637:
You can connect to a CR250, take measurements and they're displayed correctly.
If you disconnect from the CR250 and connect to a K10-A, it connects and measurements are displayed correctly.
If you then go back to the CR250, it will connect to the probe, it will go through the motions of making a measurement, but it doesn't display the data.
Disconnecting and reconnecting the CR250 doesn't fix the issue.
Rebooting ColourSpace seems to be the only way to get it to display readings again
Dave
Author Light Illusion Male
#2 | Posted: 10 Jun 2023 10:20
Are you trying to run the two probes simultaneously?
We really need a lot more info, and ideally a video of the issue - you can use ScreenPal
Online now: Guests - 9
