Bars Widget auto-scaling [Fixed]
Author argonaut
#1 | Posted: 14 Jun 2023 15:26
Here's an example in 1683:
Bars Widget 1683
I'm interested in the RGB relationship, and can't tell anything.
Here's the same measurement in 1637:
Bars Widget 1637
I can actually see something useful here.
Author Light Illusion Male
#2 | Posted: 14 Jun 2023 16:19
Thanks for the feedback - just means we need to adjust the algorithms used a bit more.
Something for the next update.
Author argonaut
#3 | Posted: 14 Jun 2023 17:23
If you want to make the Bars Widget even more useful, allow it to be popped out into a separate resizable window, or displayed in the Graph area, with full variable zoom control.
#4 | Posted: 14 Jun 2023 17:26
Having the Bars and Zoom Widgets as main graphs too, as well as therefore pop-outs, is on the WIBNI list.
