Recommended SDI Patch Generator
Author cinevation Male
#1 | Posted: 26 Feb 2026 15:50
I want to calibrate some monitors which are connected via HDMI but going through a blackmagic SDI to HDMI converter. I've used Davinci resolve as a patch generator before but it's a bit of a pain to setup and is only 10bit. Whats the simplest way I can feed a nice clean SDI feed to my monitors without having to add in multiple converters etc. I've tried the calibmate software a year or so and liked the concept of it but I just had constant crashes and issues, the software version doesn't seem to have been updated which is a bit of a shame.
TIA!
#2 | Posted: 26 Feb 2026 16:46
If the monitors are HDMI, why go thought a SDI to HDMI converter?
And did you mean to say Resolve is only 10-bit?
Author vlut Male
#3 | Posted: 27 Feb 2026 14:54
cinevation
cinevation:
Guess you mean Resolve is limited to 8-bit?
You can get round this DaVinic Resolve limitation with CS Patch Translator, software https://aulwa.com/aulwa which I am the author.
All patch generators take some configuration as they need to match the display and the target colour space, bit depth, range etc. If you are looking for recommendations, then I use the FSI BoIO and have also used the AJA ColourBox both very good.
Hope that helps.
Victor Aberdeen - aulwa
Media Engineers
#4 | Posted: 5 Mar 2026 12:29
cinevation
Which dedicated output card are you currently using?
Author tjdcs1912
#5 | Posted: 3 Jun 2026 03:56
Hi vlut,
I'm also looking into LightSpace CMS right now. I'm not very familiar with using AJA as a patch generator, but are you saying that the AJA ColorBox can be used as a patch generator / source? Is that supported directly by LightSpace CMS?
Cheers,
- Tucker
#6 | Posted: 3 Jun 2026 08:50
I assume you mean ColourSpace, as LightSpace has been dead for some years...
And yes, as per the ColorBox user guide it can be used as a TPG: https://lightillusion.com/colorbox_manual.html
Members - 2 [ Steve, Alexey ]
