Target EOTF for HDR on a computer?
Author g62385093
#1 | Posted: 16 Feb 2024 19:58
What EOTF(s) do MacOS and Windows use for HDR content?
It seems to vary (or maybe just scale) under different conditions such as:
  • With MacOS, you can use the HDR video preset to get the PQ EOTF. That's pretty clear.
  • When you change brightness in MacOS in the default preset, such as Pro Display XDR (P3-1600 nits), what EOTF is used? Does it vary across the brightness range as the SDR / HDR limits are changed? Apple documentation references a system gamma of 1.961 (at least for internal displays).
  • With MacOS, you can create custom presets using an SDR EOTF based on sRGB, BT1886, or a custom gamma. What EOTF is used for the HDR range above that?
  • Windows HDR brightness slider for external monitors seems to potentially alter the EOTF
Thanks for any insight into this!
#2 | Posted: 18 Feb 2024 11:08
Target EOTFs are always as defined by the colour space standard.
They are effectively set within the monitor when calibrated.
What 'other' non-standard variations any given OS does via its own 'colour management' is really an unknown, but is a perfect example as to why a dedicated video card is critical for any colour grading work.
To define the effective EOTF on any display, you can obviously use ColourSpace to profile the via the OS.
