LG31mu97 calibration thoughts?
Author wiski15b
#1 | Posted: 1 Aug 2016 17:12
Hey guys,
Im fairly new to this and have been doing quite a bit of research, however I'm a bit more confused than when I started my research lol...
I have an LG 31mu97 (claims to get 99.5% Adobe RGB and 97% DCI-P3) hooked up via Displayport 1.2 to a 2009 Mac Pro with a Titan X which gives me DCI 4k @ 60hz.
I plan on grading a feature film in the very near future as soon as I get my setup in order.
Questions:
-Has anyone here calibrated this monitor? I seem to have found some pre setup issues, such as, the brightness control seems to be a backlight control as oppose a way to adjust blacks.
-In order to calibrate this monitor, do I need an external LUT box, or some sort of card or decklink?
-Would it be best to calibrate the monitor in something like REC709, do my grade in Resolve in REC709, and then export in my desired color space, such as DCI-P3?
-Or would it be best to calibrate the monitor to what ever Color space I plan on grading?
-Or is my only option with my current setup to calibrate with something like lightspace and an i1 display pro, and create LUTS for use within resolve?
Ron
#2 | Posted: 1 Aug 2016 17:44
Hi Ron,
With LG displays you will never get a viable calibration without the use of a 3D LUT.
But, there are few 4K LUT boxes available, with the FSI BoxIO being the only really viable one.
See: http://www.lightillusion.com/boxio_lut_box.html
This really means using the output LUT capability of resolve would be an obvious way to perform the calibration, as many users do already.
As for the actual calibration - Rec709, or DCI P3, you really need to profile the display with a suitable probe and LightSpace CMS to see what it is really capable of, and then define your best workflow.
If the display really can get close to 100% P3, that may be viable.
But, a Rec709 calibration, with a LUT to convert to P3 after the work will always be 100% accurate.
I hope that helps.
Author wiski15b
#3 | Posted: 3 Aug 2016 20:23
Looks like I would only get 30hz at 4K with a single FSI BoxIO, I would potentially need 2 in order to get 60hz correct? would it then be a better choice to get a Eizo ColorEdge CG248-4K 23.8 or another monitor that can handle LUTS internally? If I calibrate the monitor to REC709, I wouldn't need a lut box correct? Grade in 709, then output in dci using resolves built in luts?
