About the soft roll off and the tone mapping of the BT2390-3 in the st2084
Author CQHandsome Male
#1 | Posted: 3 Dec 2024 10:03
Hi steve
In the attachment location, what is the difference between
soft roll off and BT2390 tone mapping? And in what situations should I use which one?
I read the description of BT2390, and it seems to be a kind of roll off, and it is different from the algorithm of st2094-10/20/30/40
What is the file definition of the soft roll off algorithm?
Thank you very much
#2 | Posted: 3 Dec 2024 10:19
As per the Guides:
"Within Soft Roll Off the Target upper start % options defines the level at which highlight roll-off starts, while Target lower start % defines the level at which shadow roll-off starts.
BT.2390 Tone Mapping has roll-off defined by the Mapping option presets drop-down."
Not a lot more that can be said really.
Which to use is up to the user, based on the final image.
#3 | Posted: 3 Dec 2024 10:23
So the difference is that Soft Roll Off can manually set the starting point of highlight/shadow roll-off, while ST2390 cannot be set manually and is fixed by the algorithm?
In addition, may I ask the Soft Roll Off algorithm is defined by which standard file?
#4 | Posted: 3 Dec 2024 10:35
BT2390 is defined within its standards specification.
Roll-off is just roll-off, adjustable as the User Guide defines.
Author argonaut
#5 | Posted: 4 Dec 2024 18:17
FYI, that mapping technique has been removed from the current in-force revision BT.2390-11, and instead appears in BT.2408-7 Annex 5.
#6 | Posted: 11 Dec 2024 10:13
argonaut
Thanks, I only read the latest bt2390-11 before, I didn't find this part, I saw colourspace and realized that it was hidden in 2390-3, so it ran to bt2408-7!
In addition, bt2408-7 proposes a new color coding method maxRGB, which can simultaneously prevent color space overflow and also keep hue unchanged, just can't let saturation vary naturally with brightness. But there isn't a perfect solution for all five, I wonder if steve would consider adding it
