Hi. I'm running ColourSpace HTP v. 2.0.0.2420, and just discovered that I cannot connect to my Lumagen Radiance 2020. I'm using a USB-to-RS232 cable with an FTDI chipset, and have successfully used the same setup with previous versions of ColourSpace in the past. I have reinstalled the latest FTDI VCP chipset drivers with no change. V.2.0.0.2420 does recognize and list the virtual com port that the FTDI uses but will not connect to the Lumagen. I also have the last (2019) version of CalMAN Home Enthusiast installed, and as a test, I just fired it up and connected successfully with the Lumagen, so I don't believe it's a Windows USB issue. Please let me know if there is any additional data I can provide. |
