It may happen that Tangents (if enabled) can be hardly seen in CIE windows. This depends on the fact that a measurement point is selected. The tangents, in CIE drawings are outlined in white only for the selected measurement.
As a solution, to see all of them, I unselect the point (i.e. using the manual measure sliders pointing to a not measured point).The same rule does not apply to 3D graphics, where all the tangents are always shown, regardless the point selection,
This is shown in the below screenshot combination. Above, as I was coming from built-in characterisation, the manual measure sliders are pointing at the black level. The only way to see all the tangents is by moving them (below part)
Steve, let me know, if you prefer I rewrite this post on Tip and Trick, based on my solution.
If you like, as WIBNIs I would propose to emphasize the selected tangent with a yellow line for the selected tangent and having a white colour for all of them for both 1D and 3D graphs. Also for that, please, let me know what you think about.
