Why there is no data for RGB separatation?
Author CQHandsome Male
#1 | Posted: 2 Nov 2024 15:15
Hi, my savior
After measuring 52 grayscale points with the colourspace ZRO, I found that my RGB separatation never had any data, all other charts did, see my attachment
May I ask what I have not set correctly?
Also, what does the CLIP chart mean please?
In order to simplify my understanding, I've deleted the data and only have 2 dots left, the first one is all (0,0,0) and the second one is (100,100,100), but the RGB lines in the chart are 0.0211,0,-0.0371 as shown in the attachment III.
Can you suggest where this data comes from?
Thank you very much for your help!
#2 | Posted: 2 Nov 2024 15:37
As is explained in the User Guides, you need matching R, G, & B primary measurements that match the grey scale measurements.
#3 | Posted: 2 Nov 2024 16:05
OH, thanks, I see, it needs R=G=B grayscale and separate R/G/B color grades, all four patterns together to be drawn
Thanks a lot Steve!
What about clip charts?
the User Guides are too short to understand them
#4 | Posted: 2 Nov 2024 16:37
Clip is as explained in the ColourSpace Graphs guide, as are all the graphs:
#5 | Posted: 3 Nov 2024 16:24
If you have bought Ted's calibration disk (BD-ISO, Media Files, or PGenerator), then you have access to some patchlists:
https://www.avsforum.com/threads/colourspace-zro-low-cost-manual-calibration-software-thread.3175441/post-61259901
The Quick Profile of Primary or Primary and Secondary will plot the RGB Separation graph.
Tick the AUTO radio button on your Profile luma so the software can automatically use your measured black/white measurements to generate the charts.
