Patch Generator Choice
Author chrisbobmms Male
#1 | Posted: 22 Jul 2024 18:30
Are there advantages one way or another between using PGenerator (on a Pi4 with Ted's Patches) and a monitor output from resolve to generate patches?
I'm thinking that LUT's are a little easier to apply in Resolve than if you're generating them for a LUT box, but I'm not sure which is a better signal chain?
#2 | Posted: 22 Jul 2024 21:09
PGen can do 10 bit native, and can have different patch background colours.
Resolve, due to issues with the BMD implementation of patches, can only do 8 bit input, with bit shifting to 10 bit (or other bit depths) on output, and can only use black as a patch background.
The Resolve limitations are stated on the Resolve User Guide.
#3 | Posted: 23 Jul 2024 20:45
So Pgen is probably a better choice? Would there be any advantages to using Resolve? I'm thinking if that's what I'm going to be using the display for, does it make sense to use the same signal chain?
#4 | Posted: 23 Jul 2024 20:55
Within reason, you should see no difference in the final calibration whichever you use.
Calibrate with one, and verify with the other.
#5 | Posted: 3 Aug 2024 07:07
Resolve iTPG is 8-bit while PGenerator is 8/10-bit.
PGenerator can also be used for HDR10 10-bit and Dolby Vision.
If you are going to use Resolve iTPG, you will need 0.75 sec of extra delay, while PGenerator will need 0.5 sec, so the patch generation with PGenerator will be faster.
Author HeBer_nl
#6 | Posted: 7 Jul 2025 05:18
Do you need a Blackmagic UltraStudio (or DeckLink) to use DaVinci Resolve as a patch generator? I was able to connect DaVinci Resolve Studio to ColourSpace for testing, but decided not to proceed further for now. I haven't installed a DeckLink or UltraStudio device, but I did optimize my Nvidia driver settings as recommended here: https://lightillusion.com/direct_profiling.html.
Also, ColourSpace can generate patches internally — either through the cube-based method or using the included Preset Patch Sets. Are these not sufficient? Why is there even a need for an external patch generator like Resolve or PGenerator?
LTE user.
Author ColorCal Male
#7 | Posted: 7 Jul 2025 19:26
No, you do not need a dedicated video card to use Resolve as a TPG.
But without one you will potentially suggest issues with normal graphics cards, which you have tried to limit by following the User Guide you linked to.
The main reason to use an external TPG is to prevent ICC/VCGT/graphic card issues.
Also to enable profiling of the full signal path when using Resolve or any other grading system as the TPG.
And presently, the in-built ColorSpace TPG is 8 bit only.
