LS CMS and ICC conversion workflow
Author Margus
#1 | Posted: 19 Nov 2014 11:34
Hi.
I wonder how to go with SpaceMan ICC Profile Manager.
What i have gathered so far is that i do the calibration like
usually but with help of java app that emulates networked device
which is generating patterns on my computer monitor.
This is the most confusing aspect to me at the moment.
Later i just use SpaceMan just to convert my LUT to ICC?
Margus.
#2 | Posted: 19 Nov 2014 22:03
Hi Margus,
You calibrate the display as per normal, and make the LUT.
That may or may not require the use of the Java App - that depends on the way you want to connct the display to LightSpace, and has noting to do with the later use of SpaceMan ICC.
When you have the calibration LUT, you then use SpaceMan ICC to convert the LUT into an ICC profile.
Does that help?
Author Margus
#3 | Posted: 6 Feb 2015 08:06
Thanks.
So if i get SpaceMan ICC do i also need SpaceMach?
For now i have mac machines but in not so distant future some PC's will emerge probably.
#4 | Posted: 6 Feb 2015 15:21
Hi Margus - no, SpaceMactch DCM is a separate product that you can use directly with LightSpace CMS, as it exports a VCGT LUT.
Direct ICC operation is separate.
Author Margus
#5 | Posted: 14 Feb 2015 13:05
So for my macs or future PC's i will need SpaceMan ICC?
#6 | Posted: 14 Feb 2015 13:13
If you want to use ICC profiles. then yes - SpaceMan ICC converts LUTs into ICC profiles.
Author Margus
#7 | Posted: 14 Feb 2015 13:15
Thanks!
Online now: Guests - 6
