Chroma Deous:
In the process of calibration. We're trying to find the option to change target gamma. Is this possible? My room environment is 2.2.
In the Manage Spaces window, select the Rec 709 preset color space and select "modify". Change the target gamma to 2.2 and save using a name that's easily identifiable. It will be saved in Color Spaces (user). Select the customized user color space as your Target Gamut / EOTF under "Settings" in your Profiling window.
ColourSpace HTP
CR-100 / CR-250-RH / PiTPG
