ASUS PA32DC
#1 | Posted: 24 May 2022 16:41
We have now verified ColourSpace integration with the ASUS PA32DC, and all is working as expected - according to the Dev. team.
I will have the display in my hands shortly, and will run in-depth testing.
I'll post my findings here.
Author howellsaaron Male
#2 | Posted: 25 May 2022 05:21
Look forward to seeing your thoughts on this printed RGB panel Steve. It's awesome that this has complete ColourSpace integration making it more viable than the LG monitor using the same panel in my opinion.
Thanks.
Aaron.
#3 | Posted: 25 May 2022 07:14
howellsaaron
The LG display using the same JOLED panel has no 3D LUT calibration capability - just 1D and a 3x3 matrix.
The ASUS has full 3D LUT capability, as well as direct ColourSpace integration.
#4 | Posted: 25 May 2022 07:19
Yes I am aware. I was saying because of the ColourSpace intergration the Asus is the better option in my opinion. As well as the 3dLut capabilities you mentioned.
Thanks.
Aaron.
Author babar hdr Male
#5 | Posted: 29 May 2022 10:26
Reception for test Tuesday 25th May of the LG 32 EP 950 Monitor
I thank Sebastien Collin from DID technology for helping me with this monitor and thank LG for their trust.
Early results in SDR really encouraging, this monitor is very stable.
Tested with LG and Calman software the results are good
BUT , if you want to go a very very good result like loading a 3D LUT calibration, then you will need the ColourSpace Software from Light Illusion, a LUT Box - FSI or AjA style .
You can also use a BMD converter capable of loading LUTs, but in this case you will have to apply modifications to the file of LUT to have a result that will be much more precise. I used a Mini Teranex SDI to HDMI 12 G
LG EP 950.pdf Attached file:
LG EP 950.pdf
POSTCAL LG EP950 REPORT.pdf Attached file:
#6 | Posted: 29 May 2022 18:26
Sylvian's results do indeed mirror my findings with the ASUS PA32DC, and show that a 3D LUT really is needed with these displays - you can see the non-linear issues in the pre-calibration profile, which cannot be corrected with a 1D LUT and 3x3 matrix.
#7 | Posted: 30 May 2022 12:57
Here are some quick profiles of the ASUS PA32DC.
The Precal profile maps the profile data to the native response of the display, so you can see it's relative underlying accuracy.
The profile shows approx. the same level of underlying non-linear errors as Sylvian found with the LG, requiring a 3D LUT for accurate calibration.
(A 1D LUT and 3x3 matrix will produce 'ok' results, as Sylvian also found with the LG.)
The Postcal profile targets Rec709, and shows all verification measurements to be sub 1 dE2000.
(Ignore the Gamut Coverage value - I am using an unreleased Alpha, and the reported value is wrong.)
Taking a bit more time, especially with probe matching, suggests even better result will be possible.
(I did do a second run, and got an even better RGB Balance response, but there is something slightly weird happening there, which I am discussing with ASUS.)
precal-report.pdf Attached file:
Precal
postcal-report.pdf Attached file:
Postcal
#8 | Posted: 30 May 2022 13:30
Thanks for sharing this with us. It seems to be a very stable panel with excellent accuracy after a 3DLUT for SDR and rec709 at least. I see you have used the ITPG any thoughts on it's accuracy? Would you recommend a more bit perfect TPG like the PGenerator for example? I also see you have used a reference probe in the CR-100, have you experimented with the internal probe? If yes obviously the CR-100 will be a more accurate probe but any opinion on the internal probe?
Thanks.
Aaron.
#9 | Posted: 30 May 2022 13:47
I have used the iTPG, and external TPGs, and the results are basically identical.
(If you want to use smaller TPG size windows you will need to use an external TPG, as the iTPG is FW only.)
And the in-built probe is not yet functional with ColourSpace - we have not been provided an API/SDK.
However, I would suspect it will not be accurate, as with all other in-built probes.
(If it were accurate, there would be sub $100 probes available on the open market.)
Author zmas Male
#10 | Posted: 19 Sep 2022 13:51
Thanks for the reports on this monitor. Have you tested it for HDR and HLG? Moreover, I was looking at the guide for the ASUS monitors and was a bit unclear as to the purpose of all the LUT slots. For calibration, only the 1D+3D slots should be used, correct? With the 1D Part of that slot being left alone?
#11 | Posted: 20 Sep 2022 06:10
The ASUS displays work as per the manufacturer information - including HDR and HLG.
There are 2 Calibration Slots, and either can be calibrated for SDR, or HDR - including HLG - as per the user guide.
For the LUT slots, the use of 1D+3D, or 3D Only, or 1D Only, Pre and Post the 3D, is a user choice.
There is no set requirement.
This is explained within the ASUS User Guide.
Author davem
#12 | Posted: 6 Nov 2022 09:06
Hi Steve
I have a number of ASUS PA32DC OLED displays here at the moment.
One is an early demo unit and the I have 4x PA32DC's that have just arrived.
The problem I have is that I can connect to the earlier demo unit, (with a manufacture date of April 2022), but I can't connect to any of the later displays, (manufacture date August 2022)
The Firmware in the earlier unit is "FW MCM102 B00B06" (this works fine)
The Firmware in all of the later units ai FW MCM102 B00T00" (this attempts to connect but then comes back with "Error: Connection failed to ASUS")
I haven't spoken with ASUS yet, but has this possibly come up elsewhere?
#13 | Posted: 6 Nov 2022 09:10
Nope, no such reports from any other users - but do remember you need to run CS as Admin with ASUS displays.
That is an ASUS issue.
Author davem
#14 | Posted: 6 Nov 2022 09:16
Alas that didn't help.
I'll get in touch with ASUS in the morning.
Dave
#15 | Posted: 6 Nov 2022 15:36
Dave - the latest Firmware can be downloaded via the ASUS website, and should be FW MCM203 B00B07.
(I've just updated, and all works as expected.)
The version you have there is basically incorrect, and ASUS are not sure how those displays have ended-up with it installed.
 ASUS PA32DC
