i1Pro 3 Disconnect causes Not Responding [Fixed]
Author argonaut
#1 | Posted: 2 Apr 2023 18:36
I start ColourSpace, Connect to an i1Pro 3, do the white tile calibration, and then take a set of measurements. If I then click on Disconnect for the probe, there's a reasonable probability that the app as a whole will become Not Responding. This is on Windows 10 with the 1.0.0.1582 Beta. I don't know if it happens with earlier versions.
#2 | Posted: 3 Apr 2023 10:15
Unable to replicate, so may be an issue with your PC configuration?
Possibly a com port issue?
Have repeatedly tested i1Pro 2 and 3, with no problem.
Author argonaut
#3 | Posted: 3 Apr 2023 14:46
I've used that USB port for multiple purposes, including many thousands of measurements with other probes. I suspect there's a race condition in the code, so I'm not surprised it's hard to reproduce. I can provide a DMP file for analysis, if that would help.
#4 | Posted: 6 Apr 2023 14:36
There will not be any viable data with a 'not responding' situation.
We need a method to reliably replicate.
Author argonaut
#5 | Posted: 6 Apr 2023 15:04
Not all bugs are reliably reproducible. This one isn't. (Which would be expected with a race condition.) It happens for me maybe 1-in-4 times. You can't get stack traces from a DMP file?
#6 | Posted: 20 Apr 2023 11:24
We have just been able to see this issue.
Not easily repeatable, but we will try to locate the problem.
#7 | Posted: 20 Apr 2023 17:00
Hopefully, as part of the integration changes, we have fixed the issue.
Author argonaut
#8 | Posted: 20 Apr 2023 17:13
Good to hear, thanks.
Author argonaut
#9 | Posted: 31 Jan 2024 14:07
I've had this happen again twice in two days, with 1.0.0.1756.
#10 | Posted: 31 Jan 2024 14:16
We have not seen any issues with the i1Pro probes for a long time.
Unfortunately, this looks to be an issue with actual probe firmware/driver, in specific installations.
#11 | Posted: 31 Jan 2024 15:19
Just to verify, I have spend the past hour testing an i1Pro3 - It has not had a single issue.
Nothing I can do will cause a Disconnect lock-up, or any other issue.
Author argonaut
#12 | Posted: 31 Jan 2024 16:04
Procedure: plug i1Pro3 into USB port, then repeat ad nauseam:
1. Reboot Windows 10
2. Start ColourSpace or CalMAN
3. Connect to i1Pro3
4. Disconnect i1Pro3
Hangs with ColourSpace: 100%
Hangs with CalMAN: 0%
#13 | Posted: 31 Jan 2024 16:09
As said, I have spend an hour doing repeated Connect/Disconnect...
No issues at all with my PC setup - desktop, or laptop.
Author argonaut
#14 | Posted: 31 Jan 2024 16:42
I can only reliably reproduce it on the very first ColourSpace connect after a Windows reboot. If I then terminate the hung CS and start up CS again, repeated connect/disconnect works fine. And in fact, if I reboot Windows, and then first actually use (not just connect/disconnect) the i1Pro3 with CalMAN, then exit CalMAN and start CS and connect to the i1Pro3, the disconnect will still hang.
#15 | Posted: 31 Jan 2024 16:52
I guess that suggests an issue with the driver/initialisation.
I expect Calman is not using the same driver, as with the i1D3?
That may potentially be the underlying cause of the issue.
(We obviously do not use Calman at all.)
I have again tested the same scenario (Win11 though) and still no issues.
Also, are you using the USB cable as provided with the probe, and direct to the PC - not via a Hub?
